Busted ball joints at 20k miles?
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I'm not sure what the heck it is. I mean my car just passed 20k miles recently and my front right side is clunking. It doesn't happen very often, just only at very low speeds. When I'm pulling out of a driveway or parking space and going foward/reverse while turning the wheel left to right. It makes a little clunk. There is no play in the steering, looseness, or anything. I drive pretty hard, but I didn't think the balljoints can go out so soon lol.
Another possibility is that my transmission mount broke because the clunks started a day or two after I got my turbo up and running. I'm gonna jack up the car and look around under there tomorrow to see whats up. Just trying to see if any of you with bad balljoints had any similar symptoms.
It's possible that the balljoints can be broken by now. Knowing the kind of driving you do, I'm not surprise if the balljoints really do show lots of wear. Whenever you brake and/or turn hard, you're putting a lot more stress on the joint. Our balljoints weren't design for such abuse. For now, you just gotta take it easy
![Embarrassment](https://www.clublexus.com/forums/images/smilies/redface.gif)
Make sure that you swaybar nut/bolts are properly torqued and tight. I had a front end clunk ( on the passenger side ) like you describe and it turned out to be loose swaybar nut/bolts ( infamous Daizen loosening swaybars ). Those suckers are loctited now and I've had no problems. Hopefully it's something simple.
Hm, I replaced the balljoint on the passenger side but the clunking is still there! The balljoint had a tear in the boot (probably due to me removing it
), but the balljoint has no freeplay in it so that wasn't my problem in the first place. Good thing my driving style didn't bust the balljoints, but bad thing that something is still clunking.
Oh well, the balljoints are done with and replaced so there's no going back now lol. Everything is nice and tight down there so I have no idea what the heck is making the noise...it's driving me nuts lol.
Castor arm bushing. Definitely. That is the only bushing I switched to Daizen for the same exact reason, it would clunk from the up and down movement. Visually it looked fine when taken out, but it was weak. It is such a big bushing, but most of it is empty, it definitely gives out early on our cars. I had the same thing, clunk in the front, especially pronounced when going in my driveway. It was really bad, my girl would bug out sometimes and ask me what that was.
