OEM vs. Aftermarket swaysbars? whats the diffrence?
I can not say anything, because i am very happy with the TRD . big different. I am using stock suspension. This is the only mod i have in my car, so it is not too stiff, but the handle is 10x better... I can feel it within 20mph. on the turn, the car completely flat. it worth for the money..i got the approval from GSteg
I realize the lateral handling will be much improved with better swaybars but will Daizen or TRD bars result in a harsher ride when driving straight? I don't want to give up too much daily driving comfort, especially on highways.
Three Questions,
1> Where exactly on the car are the sway bars installed?
2> Strut Bars, are they mainly for show or is there REALLY a good use for them? I've seen pics of them installed and quite frankly it just looks like a round or sometimes a flat piece of metal mounted on the frame where the shocks are located. Visually it looks useless to me.
3> Which of the two does a better job in reducing body roll lets say for a car that has a coilovers or even non-stock shocks & springs.
The sway bars connect the lower control arms.
You're going to have to go under the car to see the rear one. The front one can be visible if you lift up your hood and look at the area of the engine's crank pulley. There should be one big bar going across.
strut bar helps reinforce the chassis. It will not reduce body roll because it's just helping holding the chassis together. If anything, new springs/coilovers and sway bars will be the ones that help reduce body roll.
