OEM vs. Aftermarket swaysbars? whats the diffrence?
#31
I can not say anything, because i am very happy with the TRD . big different. I am using stock suspension. This is the only mod i have in my car, so it is not too stiff, but the handle is 10x better... I can feel it within 20mph. on the turn, the car completely flat. it worth for the money..i got the approval from GSteg
I'm glad you went with this route first.....and if you're still not happy, then you can the coilover$.
I might have to get the trd and sell my daizens and CS
For those who want the comfort while improving the handling, you should change your sways first and go from there.
#32
Fine, since you can't express it in words, I'm going to have to call you and get a ride
Check your PM for my new #
#35
On straight road, his car is still comfortable. It's only until you hit lots and lots of potholes where you'll feel the stiffness. On those speed bumps, you can totally feel the ride is firm. It's not harsh, but rather firm.
If you are looking for the cushiest ride, stick to OEM sway bars. But if you dont mind firmness on your ride, go straight to the TRD.
#36
Dung0981 has stock suspension. His only mods are the TRD sway bars and the Daizen control arm bushings. I took a ride in his car and his car was damn flat through the corners. It's quite a bit flatter than my car when i had the daizen sways (mind you I also have l-tuned springs).
#37
Sways
I've had both!
I started with the Daizens sways and liked them a lot.
I still wanted more control and a flatter ride on curves so I added
all of the Tom's braces. i liked the improvement but the tail still wanted to slide out going up hill on a curve.
So I added JIC FLT2A coilovers and the car felt transformed.
Rear end had much less tendency to slide.
I kept hearing that the TRD Sways were even better than the Daizens for keeping the car flat on curves. Without going into the story I ended up switching to the TRD Sways and they do indeed make the car go around curves much flatter.
The downside is with all these mods it makes the ride less cushy.
That is a tradeoff i'm willing to pay to get the car to handle extremely well.
I know it is not for everyone and my wife does not like riding in my car.
You do feel every little bump.
Wife and I both have 99 GS400's. She has the Daizens Sways and all the Tom's braces and the car handles better than stock. She does not want to change the Shocks as she likes to retain some of the cushy ride.
Ivan
3dog
Ivan
3dog
#38
Then upgrade the anti-sway bars, which significantly reduces that body roll more than either the coilovers or shock and springs combo.
But if you want the immediate result of signaficantly reduce body roll, install the TRD sway bars first. The difference between stock and the TRD sway bars is like night and day.
#39
Install either coilovers or aftermarket shocks and springs combo first. This way, get the reduce body roll that you're looking for and you'll also be lowering the stance of your car.
99SC42
SC400 / 300 Classifieds
04-15-11 04:40 AM
