Ball Joints need to be replaced?
Hey, I was wondering how can I tell if i'm going to have to replace the FLCA Ball Joints. When ever I reverse, and I move a bit you can actually see the whole wheel moving, it also pops. I already ordered some bushings from TM Enginering, but now i'm starting to think it's the ball joints. Thanks hit me up with some help.
You technically can't replace them without a little research and some capable machining skills-- as you'd have to cut/press out the orig. and bore a press-fit sleeve for a ball joint from a vehicle that accepts replaceables-- the key is that it would need to have the identical taper to fit our spindle--
That shouldn't be that hard to do, I just don't have a shot LCA to work on-- someone told me they'd send me theirs and just never did it--
To Check your ball joints:
Use a dial indicator-- an acceptable amt. of play is normal-- this should be close to .005" -- if I remember correctly-- In other words, when you check for play, no play should be visible-- and definitely not audible, in as: clunks or pops..
For 99% of us, it's a new control arm. There's people in the classifieds parting out nice SC's with good parts. You might check in there for a replacement control arm, and slap your new bushings in them. Good luck.
You can't check play in thousandths of an inch with a torque wrench--
A very big flat blade ( like a 3 foot pry bar) with a dial indicator clamped to the LCA and the indiicator against the spindle in a proper spot will tell you your play-
Usually a few thousandths is acceptable, maybe up to .005" -- not sure on these specific ball joints though
I got one of these... use it all the time just for this...
http://www.channellock.com/acb/store...Tongu_P4C3.cfm
I just pinch the ball joint from the top and bottom... ANY movement is bad, when you give it a good pinch, you'll feel it.
miked- Sounds like your bushings are bad.
JG- The toyota RI says to check with the torque wrench, but that's a PIA.
There will be a few thousandths of play my man--- just not like .030" --
Those pliers may be a good method to try to make the joint move, but they wont read play in thousandths of an inch--
Check the FSM --
Check the FSM --
Have the FSM... if I used a dial indicator everytime on every ball joint I would never make time... basically, no move, look elsewhere, especially when dealing with excessive (and noticeable) wheel movement. A ball joint with
.005 (which is less than two pieces of paper stacked) play will not have wheel movement.
When dealing with the torque readings... a worn ball joint will have little resistance to spinning, where a new one can be pretty difficult to spin by hand period (same goes for tierods).
I agree-- If you can SEE the movement-- it's sure as hell shot-- If it's not visible at all-- you may check with an indicator just to be sure--
But most of the time the bushings ARE the first to go and you most likely have shot bushings if you drive a Lexus that's over 10 years old period--
I'm in the same situation, I've been unable to reach todd though.. finally tried email today.
My ball joints were approaching the end of their life, so I ordered new LCA's from Aliga, not sure if I can recover the diazen bushes, I think they are gone, so right now I have he replacement LCA's and oem bushes..
Been trying to contact Todd to order new sleeves and then I can order new bushes from diazen.. I really like the POLY's they seem to absorb more of the impact on the road.
If you can see the wheel moving (I missed when you said that) --- It's no doubt your bushings--
That's asymptomatic for bushings being worn out-- strange popping, clunking, and bad alignment problems-- really the whole freakin lower arm is just flopping back and forth at the mercy of the wind--
Get those suckers replaced pronto-- you'll thank yourself-- Lexus designed these LCA bushes to last about 60k ~ 80k -- that's it-- That's a HELL of a lot of miles in Japan-- usually takes 15 years to put that many miles on a car there-- so they planned well, but didnt' design the 200k mile possibility into them-- I doubt they cared-- more maintenance revenue--
