KNOCKING noise after lowering
Banned SCAMMER
sup guys
so i just lowered my car over the weekend and now i hear a knocking or clunking sound when i turn the wheel in either direction. its fine when i go straight but switching lanes or turning i hear the clunking sound. i got the springs and shocks replaced. i think maybe somethings loose? At first i thought it was bad axles but then i remembered the cars a rw drive lol. anyone know wuts the problem? thanks in advance
Banned SCAMMER
ok so i talk to the shop today n they said the sway bar link might be loose. i cant bring back till the weekend cos of work. anyone know how to fix this problem. is there a diy? i searched but couldnt find one. it would be so much easier if i knew wut the sway bar link looked like. well if someone can chime in it would be apreciated
By sway bar link do they mean the endlinks? If it is just go underneath your car and locate the sway bar. Then just follow it to either end of the bar(s) and it should connect to the endlinks. Not sure how the endlinks are on the SC, but you may need an allen wrench to hold it in place while you turn the nut.
Zombie Slayer
Yeah. If it's the endlinks, an allen wrench and open end wrench are all you need to adjust.
https://www.clublexus.com/forums/sho...d.php?t=126977
Second picture, item circled that says "see notes"
Banned SCAMMER
update:
well i just got back from the shop. they said i need new upper strut mounts, and new endlinks. i guess thats the problem. i couldnt get the damn tire iron in becuase the studs werent extended enuff, so i had to take it back. i gotta redo the whole thing...im so bummed out now. anyone know if i have to get tt upper mounts since i have tt kyb agx? and do i have to get tt endlinks? thanks for the help guys!
