universal air suspension
Old 04-13-07, 05:28 PM
c2ispy
c2ispy's Avatar
www.universalairsuspension.com pieced a kit together for the sc/ls/is that fits directly over the OEM strut or coilovers of your choice (some coilovers may require slight modification). Go visit their site and also www.vipstylecars.com and search universal air suspension theres oodles of info their on pros/cons/etc. Hope this helps.
Old 04-13-07, 10:46 PM
mrhappi
mrhappi's Avatar
Originally Posted by ACleanSC4
And the fun begins! What size line did you end up using? Installing the valves outside or inside? I have these cool mufflers that make a "poof" sound when I use it..
Good luck!
I hope it isn't to much of a headache. As of what line to use right now I am not quite sure yet, I'm getting so many recommendations. So as of right know I will just mock up the install with the tank in my spare tire wheel housing, compressors around the same area, and there are openings in the housing which I can run the lines through. I think I will also use what they called the exhaust on the compressors so when dropping the car it would be slow and less rodeo like. I'm not sure if these things also make to "poof" sound.
Old 04-14-07, 11:36 PM
sourcemine
sourcemine's Avatar
Accoridng to Universal, you can get a deal on the kit, few hundred off, if you purchase it through vipstyle.
JHutch1986
05-16-19 02:31 PM
Erikg
RC - 1st Gen (2015-present)
10-10-16 03:26 PM
/209JOHN\
12-30-08 09:12 AM
pbbnxiltae
01-27-08 08:57 PM
BlackGhost
Suspension and Brakes
11-27-07 01:20 PM
Quick Reply: universal air suspension
