Rear Supra brakes.
Rear Supra brakes.
I don't know if anyone has posted this question before,but I need to know if the rear TT Supra calipers would fit on a 93 SC300 and if they do,what will I need to do the conversion other than rotors??
Thanks..
Thanks..
im sure it has...jsut make sure itsa full swap otherwise you need to go searching for parts..call up titan motorsports..they many have them in stock..if not im sure they could help you
I did mine several months ago. You'll definitely need the calipers, rotors & pads. You don't have to change the brake lines, except that you have to reposition it a little to the Supra caliper. You will also need to trim or straighten the dust shields since the Supra rotor diameter is larger.
Good luck!
Good luck!
Good luck!
Good luck!
I just had the ones I purchased put on, all my shop had to say was they needed to modify the rear shields, as I also had to do on the LS400 brakes on the front.
Last edited by sourcemine; 04-16-07 at 10:40 AM. Reason: forgot to add shields, oops!
I initially wanted to change only the fronts to LS400 calipers, rotors and pads, but a friend gave me Supra rear calipers. I went ahead and purchased the discs and replaced all 4 corners. Now it stops like nothing you can imagine!
Good luck!
Good luck!
I definitely think that the car stops more flat and even with the additional supra TT rear brakes. As mentioned a few posts up I have the LS400 brakes and just added the Supra TT rears, car stops 400x better than stock, and I love it..
WICKED SC4
Suspension and Brakes
51
12-09-07 11:50 AM
