need help w/ stock suspension PLEASE
Recently, I discovered in the inside of my front two tires have been worn smooth, and the driver's sign has even worn down so the steel in the tire is visible. My tires are 225/40/R18 on 7.5'' wide 18'' rims with +45 offset by the way, and I have stock suspension
So i took this to a tire shop to get an alignment and hopefully solve the whole uneven tire wear problem. They said they can't align it for me unless I have stock rims or something and then the guy told me this morning that the sides are uneven, that the passenger side sits higher so that he can't align it. I thought this might have been because the previous owner only switched the passenger side spring as the car had been in a collision so the spring was newer and didnt sag like the drivers side. He said, if I brought in new springs and new tires, he could fix everything for me for $170.
He also said something about how I need a camber kit due to the fact that SC's don't come with camber adjustment.
After doing some searching on the forums, I read all Lexus sit lower on the left side, so now I don't know whether or not to believe the guy when he says he can fix it with different springs. Also if he IS right, could I just use a different set of used springs?
If anyone could help me that would be great.
Thanks
Thanks
Coilovers could help correct the uneveness. Also there is a degree or so of stock adjustment I believe for camber. Otherwise, a camber kit is available from Daizen. It sounds like you probably have another issue somewhere though that should be worked out first.
Mortgage Slave
The SC has a bit of camber adjustment, just not a ton of it. My buddy that works at a Lexus dealership was able to align my car so I don't see why it can't be done to yours (unless the problem is more than just an alignment issue).
How many miles do you have on your SC? If the car was in a wreck the frame could be bent or you just need to freshen up all the bushings or put in the LCA's from a supra and then you get new balljoints too. I got mine from Crson Toyota about 200.00 each. Cheaper amd better than just doing the bushings
Maintenance Moderator
I hate to say it, but there is a TON of adjustment in the camber of an SC...
I've personally done alignments on these cars (even ones other shops claimed not possible)
My current car, lowered, can be adjusted from -1 degree to -4 degrees in the rear, and -.5 to -3 in the front... I've personally witnessed this and done it, and I have stock everything except supra shocks / Tein springs...
Part of your problem stems from your incorrect tire size, but that shouldn't keep them from doing an alignment... we don't have any real special alignment machine, and we can do anything from 13's to 26's on almost any kind of vehicle...
you need to find a different shop...
ok so I took my car to firestone finally for an alignment and get some new tires on.. total cost was for lifetime alignment .. balancing.. mounting 2 tires.. came out to $200. plus $150 i spent on some hankooks.. so i was thinking.. ok im done.. but noo..
sc400dave was right. im in desperate need of some new LCA's.... so they wanted to charge me $700 each PLUS $638 for labor..soo $2038 total.. im thinking.. ..well pratically crying in my mind.. because keep in mind I'm an unemployed high schooler.. so i just said. i'll come back later
so as i understand, I can get some new supra LCA's for $400 total? and how much would you guys expect me to have to pay for the labor to get them installed.. in anyone knows anywhere in socal (562) that would be great.
thanks
thanks
thanks
thanks
Zombie Slayer
Just thought of something. You said the center of each tire is worn......normally misalignment affects the edges of the tires first. Center is more indicative of over-inflation. What psi are you running in the fronts?
GOBUCS
10-22-07 03:19 PM
GOBUCS
10-21-07 11:17 PM
