DIY: IS350 front brakes (w/o removing caliper)
Old 01-02-24, 12:49 AM
  #256
Shadowmeph
5th Gear
Shadowmeph's Avatar
I am curious did you say you bleed the brakes, if so I never have had to bleed brakes on any car when I was just replacing the pads .
thats said looks super simple 10 lug nuts two pins clamp the brake pads to open them upo so that easier to get old out new in ? I never looked at how simple it was, I thought it would be the old standard of having to pull the brake calipers and then go from there
Old 01-02-24, 03:27 PM
  #257
MikeFig82
MikeFig82's Avatar
Originally Posted by 2013FSport
Folks - Dot 3 Glycol fluid absorbs moisture. These fluids are hygroscopic and need changed. Manual calls every 50/60k mi. 2 to 3 years is a good number for those intending to keep their car for years.
FWIW: Dot 4 absorb moisture quicker. It should be done every 2 years. Synthetics may be longer...
Last little bit - Do your brake fluid changes during low humidity days to reduce moisture being trapped in the system and degrading the fluid. Using fluid from an open container is BAD as it has been absorbing moisture from the day it was opened and should be disposed of. New unopened container only!
Adding to this:
https://www.g-locbrakes.com/products...20temperature.
Readily available brake grease:
naquin123
GS F (2016-present)
18
11-10-23 08:17 AM
TW99GS300
04-14-20 11:02 PM
javyLSU
Suspension and Brakes
91
08-26-17 01:58 PM
saleem
07-31-06 10:35 AM
Eric-RPS13-
GS - 1st Gen (1993-1997)
17
10-27-05 06:45 AM
Quick Reply: DIY: IS350 front brakes (w/o removing caliper)
