DIY: IS350 front brakes (w/o removing caliper)
Old 04-18-07, 06:59 AM
  #31
Gernby
Gernby's Avatar
Originally Posted by ES3
Great stuff! Curious, how much more quickly do you think the non high friction pads will wear out? Also, just to verify, are you saying you would seldom if ever have the rotors ground down?
I would expect the low dust pads will last longer than the originals.
Old 04-18-07, 08:58 AM
  #32
javyLSU
2IS OG
javyLSU's Avatar
I agree with Gernby - I chose the "old" black pads fully expecting them not last as long as the new green pads, since they're a more aggressive compound. Also, as has been posted already, it's only appropriate to resurface rotors if they're severely scored (in which case you should really replace them).
Javier
Old 04-18-07, 12:42 PM
  #33
SonnyIs350
SonnyIs350's Avatar
Awesome! Thanks For taking the time to help us all out
Old 04-29-07, 06:55 PM
  #34
caymandive
11 Second Club
caymandive's Avatar
Nice job Javy! The photos and instruction are very clear. If this isn't already a sticky someplace it should be.
Old 04-29-07, 07:23 PM
  #35
Sexi_Lexi
Sexi_Lexi's Avatar
Originally Posted by javyLSU
Because 1) I have 19,000 miles on my brakes and wouldn't feel right taking my car in for them to "fix" a problem I don't have, and, 2) I don't care about the brake dust - I like the OEM pads.
Javier
That's amazing that you're not bothered by the brake dust! Prior to getting the new lesser dust pads, my friends always asked me why I had gunmetal rims up front and not the back. Bastards. LOL! Bottom line, I couldn't stand the damn dust!
Nice write up and pics, btw.
Old 04-30-07, 03:47 AM
  #36
mctuners
mctuners's Avatar
Nice write-up.
Where did you get those decals? Don't they discolor or peel off over time?
Also, was it hard to take the calipers off and replace the pads? If the IS is similar to other cars, taking the calipers off wouldn't be a big of deal.
Old 04-30-07, 06:31 AM
  #37
jdoolitt
jdoolitt's Avatar
Thanks for the write-up. Bookmarked for later. One comment / question though. You weren't doing this with the car held up by the sissor jack were you? If so -- I'd recommend using jack stands in the furture. This was a mistake.
Old 04-30-07, 09:13 AM
  #38
projectdna
projectdna's Avatar
^ that, my friend, is what you call "McGyver Style". ingenious!
Old 04-30-07, 10:48 AM
  #39
Gernby
Gernby's Avatar
What are you referring to?
Old 04-30-07, 10:59 AM
  #40
javyLSU
2IS OG
javyLSU's Avatar
Originally Posted by mctuners
Nice write-up.
Taking the calipers off is not that difficult, but why do it if you don't have to? That's like dropping the oil pan to change the engine oil. This is the method prescribed by the factory service manual, and it's also what makes the brake job on the 2IS so easy to do. The decals I got from a guy in Houston - PM me if you want his info. I like them because 1) they're small, 2)they're a "polished metal" finish, and 3) they were $12 shipped.
I used 4 wheel chocks, a ramp, and two jacks - more than enough to properly secure the car. I would have preferred to use jackstands (much easier), but if you can tell me where to find a jack stand that fits under this car, and I'll rush out to buy one.
Javier
Old 04-30-07, 11:19 AM
  #41
Gernby
Gernby's Avatar
Javier
One thing that I'm really disappointed about whith this car is how difficult it is to put on jack stands. I really haven't figured out a good / safe way to get all 4 wheels off the ground at the same without a lift. I've thought about posting a thread for suggestions for almost a year, but keep forgetting.
All of my Hondas had a reinforced jack point at each corner of the car. Why doesn't Toyota do this?
Old 04-30-07, 12:59 PM
  #42
josephdoc
josephdoc's Avatar
So I guess there is no need to resurface the discs??
Old 04-30-07, 02:15 PM
  #43
kattanh3
kattanh3's Avatar
Thanks Javy... great write-up
Old 04-30-07, 02:47 PM
  #44
lexudv
lexudv's Avatar
When you push in the pistons on the caliper do you need to open the bleeder or the brake fluid cap or is it safe to just push them in ??
Old 04-30-07, 03:11 PM
  #45
Gernby
Gernby's Avatar
You should not open the bleed screws. However, if you keep the brake fluid reservoir topped off all the time as the pads wear, then you should suck some fluid out of the reservoir before pushing the pistons in.
Quick Reply: DIY: IS350 front brakes (w/o removing caliper)
