New TEIN CS coil-overs, where in the HELL did all that noise come from???
275/35-18
I switched out from Michelin Pilot Sport 2's with the same set up and had no problems there either. I have a sneaking suspiecion that the Upper Pillow Ball might be giving me problems since it's probably not made from rubber.
I had a similar problem. Roll down your window...
1. Take an Off Ramp exit a little faster...
2. Listen if the Roar is from the rear...if turning right on the off ramp...you will hear it from the drivers side rear fender well...
3. If it is then the offset on your rims is too high...your tire is scraping the plastic/rubbery portion of the fender well
4. You might have to get a lower profile or less wide tire..esp with the sweet drop.
Question for you regading you reply. Do you have coil-overs or spring/shock set-up?
Would you mind mentioning to anyone you know who has CS-Ts to see if they had problems?
Thanks!
Thanks for the feedback.
coilovers are easy. should take around 3-4 hours if you have the right tool.
Beats installing spring/shocks any day. I much rather not compress the springs. I didn't have an impact wrench at that time
I didn't have the right tools at the time and i was doing it in the dark for 1/2 the time, total time, it took about 4 hrs... If you have a lift, it's so much easier, but I couldn't wait until the weekend so i did it with a floor jack...
My camber is off in the rear, so my tires are at about 38 psi... I agree, 28.5 is kinda low...
I need some 18's atleast...
