What will hapeen to th e Gas tank? During install is the gas tank straps loosen to install the bar.. I'm confused..
Once you loosen/remove the 2 bolts in front of the gas tank the straps that holds the gas tank to the car will come down which in turn the gas tank will come done a little...so you place a jack stand with a piece of wood to hold the gas tank in place while you install the JDM brace...you can give me a call if want....I can explain it better
Thanks E.... I have a jack stand etc..I guess the install seems pretty easy..
Do jack the car up from the rear or from the side.. If the rear, where would i put the jack at on the car.. I have a big 3 Ton jack.. Thanks
Tony
I jacked my car from the rear gear housing, used a block of wood between the jack and rear housing, make sure you use wheel chocks once the rear is in the air the car will roll.....
