bleaded breaks wit week tap, spair on but petal go to floor
I have finaly fixed my brakes this weekend but 1 problem. both rear bleader valves are broke. I blead the fronts no prob there the rears no air came out I tried to tap the whole but the drill i had was weak. so we just slapped the calipers on good. we tried to move the car but it studderd because we have a spair on the rears is that the problem. i have new rotors and pads all the way around. when I first bought the car the petal went to the floor now it goes half way. I am very low on funds doesnt what should i do.
everything is done no leaks etc. but there a grindin noise when i accelrate it sounds like some grinding from the front rotors i think the calipers are not opening but i also did not add the little wire clips
t70 supra: Check the master cylinder but if you broke your rear caliper valves, there might be a leak causing the system to loose pressure. Are you loosing fluid?
sc300max: Nice avatar, i remember making that years ago
drgrant
03-31-19 12:26 PM
