HELP! my rotor is being eaten away alive
Ther were some werid noise coming out from the front left wheel..i thought it was a bad wheel bearing but when i checked out the brake rotor, the outer ridge is being eaten away!!! (about 1/2 inch wide around the rotor, and about 1/32 inch deep). what is wrong with my caliper/pads or perhaps my suspension? i do have worn out lower control arms bushings.
The grinding noise only occurs when i'm traveling at low speeds, and only when i'm not braking.
