funky brake sound
so im driving down the road when i hear a constant squeaking coming from my driver side wheel, sounds like my brakes are still touching the rotor. didnt happen before until yesterday, anyone know how to fix this???
Like SC300Max said, it could be a seized caliper. I had the same problem with it making a noise after letting my foot off the brake pedal, mine ended up being a seized caliper pin. The pin was stuck in the bracket good, I couldn't turn or get it out. Ended up getting a used pair of calipers from Aliga and used the bracket from that. After that no more squeeling sound when I let off the brakes. Hope this helps and good luck!
