what spring rates do you like?
i do not want a soft ride, but i dont want a teeth chattering one either. curious to see what spring rates you guys are running.
*****Do not buy from this member until further notice *****
16kg FR
11.5 kg RR
custom spring rate
i use this for time attacks with the right tires u can get 1 wheel to lift off the ground when u corner hard
11.5 kg RR
custom spring rate
the wheel lifting off the ground is only because the lowering perch is independent from the perch the spring sits on or the preload.
so when its preloaded and lowered, your suspension wont decompress and have your wheel fall... its stays tucked... so you 3 wheel... this happens to me all the time, when i go over speed bumps and up my driveway
both those rates would be what most consider "teeth chattering"
my Supra Tein S-Tech springs are 12kgf/mm and 6.5 kgf/mm
I love em - they handle well, and ride nice and tight, but still retain a comfortable ride... I suppose they could be a little stiffer, but, I'm happy...
