Camber Kits Available for the SC300?
Maintenance Moderator
Honestly, I wish I could get 5 degrees out of mine... I think about 3.5 was about as high as I could go... If I were you, I'd try to get the caster on the other side up to 4.5 - should even out the pull, and caster won't cause tires to wear badly...
http://www.yokohamatire.com/utmeasures.asp
I'm about to post a how-to on converting the Daizen upper bushing kit into a camber kit with a good bit of adjustment--
I'm basically taking the original supplied sleeves out, and using a slightly larger sleeve with a slotted hole for adjustment-- It seems better than making them eccentric sleeves, which is pretty common on camber kits that I've seen--
I'm using 1" cold rolled bar stock, cutting the bushings to fit the 1" sleeve, then milling the sleeve with a pretty wide slot--
Similar to this design-- but with only a single sleeve --
I don't think that kit will work for caster adjustment though--
I think I either need to install a single eccentric sleeve or dual eccentrics to achieve caster adjustment--
It took a bit of brainstorming to figure that out--
I'm worried that slotted sleeves wouldn't exactly bolt down just right and may have a tendency to loosen or slip-- now a single slotted sleeve may work--
Any input?? I'm wondering how much I would have to rotate the upper control arm forward to achieve a 2 degree change in caster-- (I need the caster to decrease on the passenger side) --
Maybe slotted would work though-- It won't be that hard to change if I need to later--
Also a little update. I went back to that shop I was having problems with. I had them put my car up on the lift and do my alignment. After a day of *****ing and moaning , the techs at the alignment shop were able to get the SC at
FRONT:
Left -1.0
Right -1.4
In the end they were all complaining about how hard it was to get it to those specs and they didnt even use my camber kit that I bought for nothing.
they just didn't want to do the work... our cars have the EASIEST alignment adjusters compared to almost any other car...
I think it was me that said you didn't need a camber kit....
our cars can be aligned to anything within reason within about an hour, maybe less, depending on what settings you are trying to get...
I bought my camber kit from Daizen. True, both the upper bushing kit and the camber kit are very Identical. But I dont think your project would work. If you ever take a look at Daizen's camber kit, notice the rubber black bushing with the hole in the middle? Well compare to yours. You'll see that the hole in the camber kit is not positioned right in the center like it is in your bushing kit. On the camber kit it is actually off to the side a little bit.
FRONT:
Left -1.0
Right -1.4
FRONT:
Left -1.0
Right -1.4
The slots add adjustment for camber and caster--
Sorry- They took my thread down as they thought my main intent was to sell kits-- I'll post up an info. thread after I get it installed and realigned without any mention of actually making and selling them.....
My kit was intended for caster-- my car's not lowered and never will be so I don't need a camber kit, and If I did I mentioned that I would use larger steel sleeves with larger slots for even more adjustability..
Trust me-- The slotted sleeves will work beautifully.
Notice the one's I made have slots-- like the one's they use.......
