So I just changed my front brakes....
Guest
Posts: n/a
Wow, my DIY skills are improving
Very simple now that I am thinking about it, I have L-tuned skirts so I had to use 2 jacks b/c the big jack would not fit under the skirts.
Took about an hour and 3 cases of beer but its done
I'm about to tackle mine. they are originals with 39k miles and are pulsating a little. I've got all the new front and rear oem pads,clips,pins,shims etc. in my garage. I still have to buy new brembo oem style rotors and ate blue fluid from tirerack.
did you turn or replace the rotors? how about a flush?
Guest
Posts: n/a
It was simple, I didn't take pics but can walk you through it if you need help.
brakes are easy... i like to use the special brake grease that lexus/toyota has to lube my shims and fitting kit... and i use sil-glide (silicone grease) to lube my caliper sliders...
if u go to any toyota dealer ask them for the special brake grease that they used for squeaky sienna brakes and most parts guys should know what you're talking about and sell you a tube... it's not cheap, but it's the best and quietest stuff around!
chuckb
02-22-07 06:30 AM
TMaxxTim
Suspension and Brakes
12-14-05 01:45 PM
