help.. squealing when turning
So I just got my front LCA bushings replaced, then I took it to get aligned. The same day I noticed a scraping sound in the front passenger wheel when I make left turns. It sounded really bad, but the next day it got noticeably quiet, then by the end of the day, it was louder again.
Is this a problem with the caliper scraping or something? whats the problem and how do I fix it
If anyone knows, please help me
Thanks
Thanks
it could be your rotors rubbing against the brake shields. check if it has any rub marks, it could've been bent a little when u replaced your lca's. if that's the problem, just try to push it back away from the rotors.
had the same experience when i replaced my upper control arms, it made a scraping sound when I make a full turn.
hope this helps!
hope this helps!
Yamae
15
04-24-23 10:34 AM
