BG racing Coilover installed...initial set up and reviews.
So Jet, I imagine by now you have got them adjusted to your liking. How do they work? Are worth looking into or should I just be safe and get the Teins? The reason I seem to like the BCs better is because they are powder coated and Teins are not, hence why they are prone to rusting.
http://www.bcec.com.tw/
I did a search on Google for "BC coilovers" and came up with a few hits. Supposedly these are in the same range as Megan's, K-Sports, etc.
I would put tein in that category as well. Tein seem to be very low quality for the price. I like the BCs better than the teins because they are powder coated which will prevent rust. The Teins have tendency to rust which means they aren't coated properly and are made of low grade material. I wish KW or Bilstein made coilovers for our cars, at least they are nickel plated. Maybe I will just have to settle for eibachs or get a set of Zeals. That is what I have pretty much narrowed it down to, from one extreme to the other.
This current set up is pretty good for street use, i set it to 18 towards hard and it is a slight bit firmer ride than the regular sport suspension that came with the car. I think zeals and teins both are really good, but eventually i would like to upgrade it to Ohlins when they become avaliable.
GTspec developed this set, its going into final production as we speak so i think it should be available very soon. i am still working on a more aggressive spring rate for track use on the IS250, maybe 12 kg front and 8 kg rear. but for street the springs that came with it is fine. just a bit firmer but not harsh. great fitment and quality.
Tech Info Resource
I have asked several times about the BC coilovers and some have said they are comparable to Ksport and Meagan. I know they are the manufacturer and they cost about $400-$500 more than Meagan or Ksport so I assume the responses I got were wrong. I may pick up a set of BC coilovers when I get a few more bucks together.
