Like a 5-series
I want my GS to handle and ride like a stock 5 series. Which suspension setup would accomplish this? Comments on tire size and profile would also help.
Thanks
Thanks
Well lexforlife may have the answer to this since he has had bimmers and his GS handles like a bimmer...
Tein Flex, Tom's LCB, Tom's 6 link kit, Tom's rear LCB, Front/ rear STB's, new ball joints, new caster arms, and probably new bushings in the front LCA's... Just a few things.. LOL![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
and last but not least.. BBK...![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Guest
Posts: n/a
I've driven stock/modded 5s and GSs...
You will never match the 5 steering but you have a 2003 GS which has hte re-tuned ECU. Handling wise
1. TRD Sway bars= less sway than the 5 series. Your car will actually be more balanced.
2, Shocks/Springs= You can go wiht L-tuned/Eibachs and KYB shocks, you don't have to do anything too drastic. You get coils and your car will outhandle a 5.
Anything else simply makes things tighter. Those 2 things are what you need.
jeff rape is not the word , the look on m3 and m5 owners faces is pricless when i am sitting on their bumper in and out of traffic (safely guy
to get control of the gs all thats needed is part of what sicklex stated however instead of shocks and springs which will never be dynamically balanced the teins c2 V2 , daizen sways, must have rear 6 piece links and front and rear lower control braces and front upper strut tower bar and a nice set of 19in staggered lightweight wheels
Actually, the funniest thing was the look on most of the other drivers faces when we rolled in "big" 4 door sedans lol
tony you are so right brother
and you be grinning![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
Guest
Posts: n/a
No the basics are the same, you can upgrade to the GS 430 ECU if you cannot find an L-tuned one. THey are the "Euro" spec ECU, since they like tighter steering feel there.
Otherwise all suspension pieces are the same. The GS 400 might even feel a lil sportier than a 430 b/c you have e-shift.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
