I need pillow upper mounts.
Does anyone know where I can get HKS or TEIN pillow uppermounts for all four struts? Let me know, i've been searching still no luck.
*****Do not buy from this member until further notice *****
thats because no one makes pillow-ball upper strut mounts. we have a double wishbone suspension u adjust camber with camber adjustment plates. the strut tower uppper mounts are solid metal from tein and they come in yellow or silver good luck. u can reuse the factory upper mounts but they are made of rubber and will absorb most the stiffness
I have air suspension and the stock upper mounts are all worn out on mines. I'm trying to drop the car lower, and with aftermarket uppermounts, I can drop my car a lot lower. These parts exist because I've seen them installed on KYB GR-2 struts for the SC along with Universal Air Suspension bags.
Maintenance Moderator
ok, so, you need upper shock mounts...
nothing pillow about them (as there is no turning movement in the shock, as it is a shock, not a strut)...
upper shock mounts - try that search
but after a quick search,and a quick thought... theres not more than about half an inch between the upper spring andthe body itself... you aren't going to gain more than 1/4- 1/2" and that would be taking the upper shock mount out of the picture entirely...
there just isn't much space between the upper spring perch and the frame itself, else there might be some room...
Yeah, i see where you are coming from, BUT, I have proven results with the HKS mounts. With the HKS mounts, It drops the car an extra good inch or so and I just need to find a distributor/dealer/retailer for them.
imo it does really matter what brand. there really are no moving parts except for hte pillow ball that pivots about the center. its just a 1/2inch thick aluminum plate with a pillowball in the center. i have tein upper mounts. i changed shocks along with the uppermounts. doesnt sound/feel as sloppy as before.
