Supra TT question
Old 06-10-07, 02:01 PM
bighitbike
bighitbike's Avatar
Default Supra TT question
Hey guys I am looking at getting some supra TT brakes for the fronts. They are just bolt on right? Will they work with stock rotors? What about stock lines?
Thanks,
Elliott
Old 06-10-07, 03:17 PM
GSoup
GSoup's Avatar
Direct bolt on but you need to cut the dust shield. You need the supra TT rotors and yes you can use the stock lines but the little hook part of the fitting doesn't line up on the caliper.
Old 06-10-07, 04:05 PM
AristoPra
AristoPra's Avatar
I'm on the same boat as bighitbike and will be going with the stainless steel braided brake lines! so what did you do to solve the alignment problem?
Old 06-10-07, 04:41 PM
bighitbike
bighitbike's Avatar
What does that mean? Would I need to fab something up to get it to work?
Old 06-10-07, 11:46 PM
GTS_007
GTS_007's Avatar
I am doing this swap this week ill take a few picture to show you.
Old 06-21-07, 12:30 AM
400DGRZ
400DGRZ's Avatar
Update??....
Old 06-25-07, 04:27 PM
GTS_007
GTS_007's Avatar
Sorry guys, camera broke but here the pic
have to bend dust cover back it will hit the rotor and the lower ball joint's so it has to be in the middle
heres with the wheel on, i had a post a while back about the wheel offsize, would it clear or not.It almost didnt 1mm gap i didnt want to buy a new set of wheels just for the brake's installed.
Hope the picture helps
Deception
Suspension and Brakes
12-14-10 08:42 PM
GoldGS3
GS - 1st Gen (1993-1997)
08-16-07 06:00 PM
Deception
12
11-03-06 05:06 AM
persian451
02-22-05 11:34 AM
Blue98Gs3
14
12-19-03 02:24 AM
Quick Reply: Supra TT question
