Rear Hub question?
Rear Hub question?
Are the Left and Right Rear Hub (including wheel bearing) interchangeable? I can't seem to figure it out, all the part #s that i've found for rear hubs don't include whether it is for the right or left side. Does anybody know if they are interchangeable?
THATS the information I needed. I have an extra rear hub from the left rear of an SC300, you're saying I should be perfectly fine to use that on the right rear of my SC300 correct?
OK thanks, I will be changing out the entire HUB ASSEMBLY though not just the bearing, so I want to be sure that left rear HUB ASEMBLY will fit onto the right rear as well? One part#, I figure its the same part on both sides. It's just my intuition told me it might be different since they are different sides of the vehicle.
