Rattling Noise When Going Over Some Bumps
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
I Have A 2000 Gs400 With Just Over 92k And I Just Started Hearing A Annoying Light Rattle When I Go Over Some Bumps (like A Taxi)....could It Be The Struts Or Bushings......i Dont Want It To Start Sounding Like A Taxi Cab...lol So I Want To Fix It Now.....help Me Please....any Suggestions
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Thanks I Will Check It Out......does The Upper Ones Go Bad...and If They Are Do I Need The Whole Assembly.....but I Am Definitly Going To Replace The Lower Ones They Are Only 123.00 On Swell Lexus....AND SHOULD I JUST BUY A BUSHING KIT AS WELL AND JUST REPLACE ALL OF THE RUBBER.
First off Welcome to CL..
Is the sound in the front or rear.. IT could be balljoints, bushings, or brakes.. With 92k on the car that means all the rubber has 92k on them and there problably worn..
Try to search because a lot of us have had the same issues and this dates back all way to 2001 with this issue.. GL..
Thanks for the welcome .....its great to be a part of the team....i believe it is coming from the rear but it doesnt happen all of the time....just certain bumps
If it is in the rear, then it is not the ball joints. If the clicking noise from the rear brakes is just one or two clicks when you accelerate after braking, it could be just the pads shifting. In terms of the front, as tmf2004 said, with that many miles, the rubber components in your suspension will have some serious wear.
