IS350 bbk upgrade
#31
Tech Info Resource
Big brakes won't change your ability to stop in a single event. They may change your ability to slow repeatedly (or they may be worse depending on your pad selection.)
You might want to take a look at this article about brakes and braking systems before spending your money.
#32
yes i have already read this article by you on one of the threads on brakes. that is exactly my point. change my ability to slow repeatedly. meaning if i have to make short stopping distance at high speed. i would not like to have much brake fade for repeated stops. especially when i take the car to the tracks.
#35
actually sorry guys i canceled my order. just didnt think it was worth it to buy stock brakes. i will however get back to you when i get some aftermarkets
#36
I think the OEM 350 brakes would be the best option regardless of price. If you buy a "cheap" BBK (less than $5K), I'm sure it will suck *****. Designing a properly matched BBK is not cheap, which is why the reputable companies charge so much. If it isn't properly matched, your ABS performance can become erratic, brake bias might be wrong, pedal travel may increase and become mushy...
#37
Tech Info Resource
Interestingly enough, it appears the 250 auto and 350 auto share the same master cylinder, but the 250 MT has a different one. This could complicate things for MT owners if the master cylinder pistons are not the same diameter.
#38
#39
so i would be able to install a bbk meant for the 350 onto my 250AT?
#40
Tech Info Resource
^^ have you checked out the FAQ whitepapers on Stoptech's site? There's a lot of good information there about the reasons why an "upgrade" needs to be carefully engineered.
johnnyboy
Suspension and Brakes
10-07-13 12:18 PM
