Need Help with how to remove and grease Daizen front sway bar bushings.
My front Daizen sway bar bushings are squeaking bad - would someone please post directions on how to remove the bar and lube up the bushings.
Or maybe you don't have to remove the bar - I don't know and I'd love to get some directions on this on how to lube the Daizen front sway bar bushing. All help is very very much appreciated!
Scott
Scott
Try using some dry greases like molybdenum di-sulphate, or graphite paste.
http://www.tribology-abc.com/abc/solidlub.htm
Best bet is to remove the bushing,
spray, or paint on that stuff,
wait about 10 minutes for it to harden a little bit,
and bolt it all up.
It lasts about 20,000 miles each time I do mine !!
and bolt it all up.
With this info I was able to take them off and grease them up really well today. It was a pretty straight forward job now that I had the info to it with!I used Mobil 1 synthetic grease. I'll post latter and let everyone know how this grease holds up.
Scott
