Tein SS vS CS ::: How Low can you go:::
Old 06-29-07, 02:53 PM
t0e
t0e's Avatar
Thanks for the info guys!!!
Old 06-29-07, 03:17 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,975 Likes on 2,405 Posts
Also something to keep in mind, this is a visual performance mod, not a mechanical performance mod. Lowering the car this much typically means the roll centers are below pavement level and the roll couples are extremely long which means the car will want to roll a LOT more in a turn. This necessitates extremely stiff springs to prevent excessive roll.
So, it may look cool, but it will not help you drive around corners faster and may actually make the car slower around corners.
Just food for thought.
Old 06-30-07, 12:43 PM
t0e
t0e's Avatar
Interesting Lobux...
I thought lowering you car kind-of reduced body roll....
But i guess at some point, going beyond the limit can actually increase it...
Strange how that works.
Thanks for the 411
Old 06-30-07, 06:11 PM
ohnoitsmo
ohnoitsmo's Avatar
thats odd, wen i had my rsx-s slammed all the way on my Tein type s coilovers, i thought it would effect the cornering but instead it seemed as if i had no body roll what-so-ever
Old 06-30-07, 06:18 PM
t0e
t0e's Avatar
Originally Posted by geri&eric
So basically I just bought tein ss for an is350 and slapped them on to the 250.
t0e measurements are 21 and 3/4 of an inch (front) and 21 and 1/2 inch (rear) from the bottom of the fender well to the bottom of the rim.
Ok guys... For the record. I went out an did my own measurements.
Left Front = 22.5 (22nHalf)
Right Front = i didnt measure but im sure its about 22.75 (the passenger side always is higher, for some reason)
So there you go... 1 more inch of a drop for TIEN SS owners
Old 07-01-07, 11:39 AM
07IS350
07IS350's Avatar
A lil off topic, but wanted to know if both are edfc compatible and wich model is better as far as construction(engineering)? Thanks in advance
Old 07-01-07, 12:25 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
That's because Tein specifies springs typically twice (or more) of the stock rate. This makes the car very stiff and reduces compliance most often when you need it most like braking over washboard surfaces. My tC had this problem and nearly got me in an accident when the ABS refused to allow me to lock the wheels and the wheels refused to follow the road surface, so I go almost no braking while the car was bouncing off the tops of the bumps. FWIW, it wasn't a panic stop when I started braking, and I had lots of room, but after the car failed to slow, it turned into a panic stop very quickly.
Old 07-01-07, 06:47 PM
ONEdirty23
ONEdirty23's Avatar
Just curious for the owners who have the SS and the CS, how different is the ride comfort between the two types of setups?
Old 07-05-07, 06:40 PM
t0e
t0e's Avatar
Comfort VS Sport = Think about it
Old 07-05-07, 10:15 PM
sykocus
sykocus's Avatar
Yes, but of then names are given for marketing reasons and don't live up to reality. I'd be nice to have first hand confirmation.
Old 07-05-07, 11:15 PM
pylee257
pylee257's Avatar
i have the SS. its pretty sporty. with 9kg spring rates. nothing meant for autox or drifting per say. but for street its definetly enough.
Old 07-07-07, 01:12 PM
Blk_An_Tan
Blk_An_Tan's Avatar
I have not done a lot of research bc i just recently bought an 07 IS 250 but i am trying to take in as much as i can.
How much do a set of tein's go for?
Old 07-07-07, 02:35 PM
t0e
t0e's Avatar
I have never driven in a car with SS, so i would not know.
However, the Tien CS is really soft. I can imagine that the SS is much stiffer and would bother most IS / Lexus owners looking for the stock (IS) ride feel...
Old 07-08-07, 02:19 AM
pylee257
pylee257's Avatar
yo ill take you for a ride sometime. it would suck if you bought it but didnt like it. call me up sometime when your in glendale
Old 07-08-07, 02:47 AM
t0e
t0e's Avatar
Cool, I'll let you know!!!
Ikonz350
Suspension and Brakes
07-07-08 09:55 PM
girlilove
02-21-08 08:30 AM
YoungP08
12
10-29-05 09:25 PM
dgtbullet
10-25-02 02:40 AM
Quick Reply: Tein SS vS CS ::: How Low can you go:::
