Last edit by: IB Advertising
Browse all: Steering and Suspension
- How to Change Ball Joints
Step by step instructions for do-it-yourself repairs
DIY Lower Ball Joints for the 2nd Gen GS. - Step by Step Instructions and Pictures
#61
Nice write up.
I plan on taking a road trip to Cali next week and I will make sure to check my Lower Ball Joints.
Chances are that I will be buying New Lower Ball Joints and following your write up. I don't want to chance the LBJ breaking on me.
#67
Just finished replacing lower ball joints and tie rods. Got them shipped from Sewell. With discount 226.00. Took 90 minutes. Must have a quality pitman arm tool. Not Harbor Freight garbage. Clamps wanted to spread, before stud came out. Had 92000 on odometer. Much tighter steering feel. Will be safe and get alignment next week. Post and pictures helped much. Although pictures just stopped working a few days ago. Maybe saved 2-400. Yeah Baby.
#69
nice write up i am waiting for my lower ball joints and tie rods along with my front bushing kit and steering bushings... from tm i can not wait to get them!! btw anyone have problems contacting tm engineering?
#71
Swollio: you don't need pictures i just did mine last week and when i went back to check the instructions on the forum the pics were gone.
But it is really easy(easier to do with a buddy though). All you have to do is take of the tire and then behind the rotor there is two 17?mm bolts that secure the BJ to the rotor(FYI once you remove those two bolts the whole rotor arm can be pulled away from the car this will give you a little more room to remove the other bolts this is were your buddy comes into play) then there are two nuts that look like crowns and they have pins through them, remove the pins and then remove the two nuts (preferable with a breaker bar) then attach the pitman puller to the exposed bolts, you have to wedge the pitman puller in between the rubber grommets on the BJ so that it fits snug against the bolts then they should pop off. Then swap in the new BJ's and put everything back together.
#72
My brother and i just purchased parts from Sewell today and will be installing this weekend. Thank God for this Thread! Saving BIG on labor and parts from local lexus dealership.
#75
