What's the correct size Earl's Solo Bleeder?
not sure how thick the pads were, but it was about time for replacement. i never replaced the brake fluid since i purchased the car in 5/2006, 40,000 miles ago. the pedal starts to feel stiff when i press it about 10% of the way down. i would compare it to the feel of the pedal when you pump your brakes when the car is off...
are these the correct size for the fronts is350?
front = 10mm x 1.0 x 35 (or 38), http://www.summitracing.com/parts/EAR-280041ERL/
iam unable to find the 38 on this site..they maybe unavailable anymore..
rears =7mm x 1.0 x 34mm. http://www.summitracing.com/parts/EAR-280025ERL/
Tech Info Resource
Hey all, I tried to install 280025ERL on the rear of the wife IS250 and it wasn't able to properly seat. The factory rear bleeder uses a 10mm wrench and the 280025ERL uses an 8mm wrench. When I tightened the 280025ERL down it never felt seated and almost felt like I was going to strip the threads. I don't know if others have experienced this
Hey all, I tried to install 280025ERL on the rear of the wife IS250 and it wasn't able to properly seat. The factory rear bleeder uses a 10mm wrench and the 280025ERL uses an 8mm wrench. When I tightened the 280025ERL down it never felt seated and almost felt like I was going to strip the threads. I don't know if others have experienced this ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
