Too low = No Alignment
Old 07-23-07, 07:33 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Originally Posted by rcsup1
I am have this issue right now...how would you do this ?
How low is your car that you can't get the alignment back close or in specs?
Old 07-23-07, 07:48 AM
rcsup1
rcsup1's Avatar
Its lowered on tein cs coil overs..there is about a finger gap between the tire (18" rims 235/40...295/35) and fender. similar to your sig.
passenger front is fine ....drivers front is maxed at - 1.14 passenger rear is maxed at -1.68 drivers rear -1.46
Old 07-23-07, 08:01 AM
mitsuguy
mitsuguy's Avatar
I'd leave it... thats not enough camber to cause wear issues... so long as the toe is set correctly, I'd leave it as is... (but even them out side to side)
I run -2.1 front, -2.7 rear and my tires have almost even wear - only about 1/32 difference from inside to outside (on the rear only, the fronts are evenly worn)...
Old 07-23-07, 08:36 AM
rcsup1
rcsup1's Avatar
Okay cool... thanks for the heads up
Polo708
Suspension
05-29-14 10:32 AM
jjffyy
Suspension and Brakes
10-10-11 03:50 PM
Infamous 1
NELOC
07-23-10 10:59 AM
aspguru
03-05-06 12:09 PM
Quick Reply: Too low = No Alignment
