I just saw that these are on sale in the CL Vendor Marketplace, thinking of getting a set.
I am a little confused, if I am getting a set of Megan Coilovers with the TRDs do I need to get new end links?
That's a strange question. Why would you need new end links? If you don't drive it hard...I don't see any reason, unless it's damaged, to upgrade. Of course, the end link will be the new weakest point now that the bars will be stiffer with TRD sways.
I intalled trd set front and back. Not that much difference. It balanced the handing to make neutral instead of plowing and follows the line you point it at better.
None, it's a piece of cake. If you've changed the oil in your car you can do this. Air tools are a plus
Dont expect too much handling improvement. It won't compensate for 3600 pounds of weight. Damn car is just too heavy.
If you live in el paso I can help you install them
This was one of the first mods I did to my car and I noticed a huge difference handling wise. Taking turns at higher speeds the suspension felt more tighter and stiffer. Before it felt like the car wanted to roll over!
These cars should've came with these sway bars stock, I mean your not gonna get the handling of a bmw but you gotta remember this car was not built for strictly performance/handling. Any suspension improvements is just a plus.
