Brakes question for 2004 gs300
Old 07-10-07 | 06:01 PM
gs300joe's Avatar
gs300joe
Unhappy Brakes question for 2004 gs300
Hello there,
Is it possible that rear brakes go out quicker than the front ones? I had fronts and backs replaced the same time when my car was at 20k-25k miles, but now my car is at 40k miles and my back brakes look more worn off (visually) and the brake sensor light below the sterring wheel comes up. My driving is very conservative. Can someone help me with this question?
Thanks much
Old 07-10-07 | 06:47 PM
GS FONZy's Avatar
GS FONZy
yes, but it is usually the other way around. it also depends on the type of pads that were installed the last time, compared to your front ones.
Old 07-10-07 | 09:51 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
Originally Posted by gs300joe
Hello there,
Thanks much
We have a brake sensor light on the GS? I didn't think we did. Also, in the newer GS's, they came with electronic brake distribution, which evens out the braking power, to reduce brake dive, and accommodate for rear passengers (added weight).
DO you have a lot of passengers riding with you? heavy trunk load?
I am assuming when you changed the pads initially, you used OEM for both axles.
Old 07-12-07 | 05:34 PM
gs300joe's Avatar
gs300joe
No I don't have passengers and I'm not even carry heavy load in my trunk and yes front & back brakes are OEMs, it's just does not make sense to me that the backs get worn out quicker. Thanks for post/reply guys.
Old 07-13-07 | 08:32 PM
e-man's Avatar
e-man
Hello there,
Thanks much
Are you sure the brake sensor light isn't the emergency brake light? Try pulling the release for the e-brake and see if it goes away.
Old 07-14-07 | 12:12 PM
JeffTsai's Avatar
JeffTsai
Yeah, there is no brake pad sensor on our cars. I'm 99% sure that you just accidentally nudged the parking brake when you got in/out of the car. Pull the brake release and that light will go away
Old 07-15-07 | 10:34 PM
GRAND_LS 4's Avatar
GRAND_LS 4
3UZ-FEEEE
When your pads are on thier way out, they start using up brake fluid... which then trips the emergency brake light. Check your fluid.
Old 07-16-07 | 03:19 AM
ILOVEGIRLS's Avatar
ILOVEGIRLS
i replaced my rears twice before i replace the front once. the second time around on the rears, i found that the caliper was stuck.
oh yeh, as the other have said, there are no brake sensors.
andy2812
Maintenance
12-16-21 08:38 AM
mbz560
10-22-12 06:00 PM
ImWildBill
11-27-11 07:57 AM
andy2812
Wheels, Tires & Brakes Forum
10-05-03 08:49 PM
