60bucks for 2-3 degree camber fix?
Old 07-16-07, 02:29 AM
kit cat
kit cat's Avatar
Default 60bucks for 2-3 degree camber fix?
6000yen (about 60bucks) for that purple thing that allows you to adjust camber by 2-3 degrees. Is there anything like that in the States?? I'm thinking about lowering my GS4 soon and was looking for a cheap fix for slight camber.
You Zealand
Old 07-16-07, 09:56 AM
chrispy
chrispy's Avatar
I don't see that listed on the website. It could be worth it depending on how low you go. I was actually looking at those SS kits to lower the car more. But for $200 I might try other alternatives.
Old 07-16-07, 10:04 AM
svt5150
svt5150's Avatar
Contact John @ Exact Motorsports. They have "camber blocks" similar but they are a little more expensive. For 60 that is a bargain if they are good.
Old 07-16-07, 10:37 AM
chrispy
chrispy's Avatar
How much are the camber blocks from Exact? That's what I'm looking for.
Old 07-16-07, 12:33 PM
svt5150
svt5150's Avatar
They were $100ish for the 1st batch. Real world results are still being done but some of the NorCal guys have been using them from 6 months or so.
Old 07-16-07, 01:28 PM
chrispy
chrispy's Avatar
Can they still be purchased?
Old 07-17-07, 06:09 PM
jriggs
jriggs's Avatar
those look pretty simple, if i could find better pics specs or something to gauge there size off of i could probably have a buddy at a machine shop make them for next to nothing... calling jay to see what he thinks right now...
Old 07-17-07, 06:27 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
looks like the rear..anything for the fronts?
Old 07-17-07, 07:44 PM
JeffTsai
JeffTsai's Avatar
I think the front RCA's were available for like $100-150 or so. That helps the camber out a few degrees as well. Not sure if anyone is still making them though.
Old 07-18-07, 03:11 AM
sleeper408
sleeper408's Avatar
I have EM camber blocks installed along with the Tein CS v2 and a good 4-wheel alignment. I have no camber or uneven tire wear.
Old 07-18-07, 05:54 AM
trancuongv
trancuongv's Avatar
what exactly is EM camber blocks? are they for front and rear? how much and where can i get these from? easy to install? please advise.
Old 07-18-07, 09:34 AM
bugeyeGS
bugeyeGS's Avatar
how low did you go ?
Old 07-19-07, 10:12 AM
HKGS300
HKGS300's Avatar
What material / material grade is used for these blocks?
Old 07-19-07, 10:52 AM
T.K.O.
T.K.O.'s Avatar
when u guys are adjusting the camber are u aiming to make the wheel more straight or angled.. i know some appreciate a straight up and down look but i dig the bent wheel
Old 07-19-07, 12:32 PM
chrispy
chrispy's Avatar
I like the negative camber look too but tire wear is pretty bad.
Quick Reply: 60bucks for 2-3 degree camber fix?
