For those w/ bilstein shocks
Do they come w/ dustboots?
Are they adjustable?
Do I need to, or should I, cut/trim the bumpstops?
Not having much luck there...
Originally Posted by Bilstein's webpage
2003 LEXUS GS430 [ switch vehicle ]
Search Results for '2003 - LEXUS - GS430'
Results 1 - 0 of 0 Page 1 of 1
Contact one of our distributors to check for shocks for this vehicle
I've tried the first 2 and I recommend the HD even though it is more expensive than the Sports-provided you are not lowering your car.
So to answer your question regarding the shocks only:
no dustboots
not adjustable
no need to alter the bumpstops
I am planning on coupling it with some H&R springs, so should I go to the Sports instead of the HD?
I think I'm going to try and get some dust boots for these. A blown coilover on my last car ended up being a real PITA.
UPD:
I was told by Bilstein rep that there is nothing (except PSS) for the GS430![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
PN# F4-BE5-2743-H0 - is for 1998-2000 GS400 and 1998-2002 GS300.
http://www.bilstein.com/303passengercars.pdf
http://www.bilstein.com/mistore/prod...pany_id=100484
Seems will have to search for something else..
I tried the Bilstein Sports before and they were far too bumpy. The HD is a happy medium between the Sports and the KYB GR-2's.If comfort is important to you, don't lower the car.
Also - what should I change at the same time - strut boots? (Will KYB boots fit Bilstein struts?).
Should I change strut mounts as well (again KYB)?
I have the sports and don't find them harsh. If you're worried about ride harshness, go with softer springs and firmer dampers. https://www.clublexus.com/forums/sho...d.php?t=297958
Hi all,
I actually called Bilstein and was told that HD are meant to be a direct replacement to stock. SP are supposed to be used with lowering springs. I thought that since I was spending money to lower the car, why not make it a little sportier at the same time. Yes, SP is a little stiffer than HD. But I am fine with the SP set I got. Hope this helps.
On a GS4XX you can use either Bilstein although, as pointed out, the Sports are firmer. I don't find the Sports objectionable on the GS430 but they are firm. If you have a GS3, you will hate the Sports unless you alternate with a buckboard and find its ride smooth.
HD's when matched with progressive springs feel much better than with the crappy oem springs. i actually found them more harsh with the OEM springs...strange.
SeattleGS400
12-31-10 01:09 PM
BottomsUp
Suspension and Brakes
07-01-07 06:19 PM
