[NEW] Tanabe Sustec Pro Five for IS250 and IS350
Old 07-28-07 | 03:18 AM
r100s's Avatar
r100s
Default [NEW] Tanabe Sustec Pro Five for IS250 and IS350
VIDEO CLIP on how TANABE TEAS working inside the car. The car in the video is RX-8.
Clink the image below.
Just got this yesterday.
This is the Tanabe's new Sustec Pro Five for Lexus IS250 and IS350.
Will also be getting the TEAS installed at once.
Here are the pictures and will be getting them installed very soon. Will also post a write-up on how they ride after getting them installed.
Old 07-28-07 | 03:19 AM
r100s's Avatar
r100s
Old 07-28-07 | 03:28 AM
2slow's Avatar
2slow
does the TEAS monitor your suspension or can it control it also?
Old 07-28-07 | 03:36 AM
r100s's Avatar
r100s
http://www.tanabe-usa.com/coilovers/teas.asp
Its the best on the market.... Ive used Tein's EDFC before and EDFC has be changed manually on the settings but this TEAS can be programed so that the presettings can be changed automatically on different driving speeds.
There used to be a video clip of RX-8 with showing how TEAS works but I can find it right now......
Old 07-28-07 | 04:51 AM
PharmISee's Avatar
PharmISee
very nice coilovers. how are you gonna do your installation?
Old 07-28-07 | 07:15 AM
TLe2006's Avatar
TLe2006
how much you get for it?
Old 07-28-07 | 07:20 AM
Seize's Avatar
Seize
Loves Snickerdoodles!
Nice
Old 07-28-07 | 11:37 AM
sincityIS's Avatar
sincityIS
That looks real nice. Hurry and get it all put on so we can get a writeup. I just ordered the Tein CS coilovers. I should have them on by the end of next week. I will post when I get that done as well.
Old 07-28-07 | 07:32 PM
r100s's Avatar
r100s
$1100 including installation from SPEED CONCEPT. (503)356-2222 PST.
TEAS was purchased before....
Old 07-29-07 | 06:38 AM
2slow's Avatar
2slow
When you get it installed, tell me how it works! I might consider it...
Old 07-29-07 | 11:48 PM
r100s's Avatar
r100s
Got the coilovers installed.... TEAS will be installed in few days....
Write-up on how the product performs will be posted soon.
The installtion went perfect and so far no problem... will be testing soon.(Driving hard on mountain roads).
The installaton was followed by the recomended setting from Tanabe as of 20mm from the lowsest to raise up the height adjusting nuts..
The installed IS was 07 IS250 RWD and the factory riding height was following (Distance between center of the wheel and the highest pint of fender lip(from center of the wheel to straight up tp the fender line),
Front: 14.5inch
Rear:14.5inch
(for both DR and PS)
After with Coilover,
Front:13.5inch
Rear:13inch
(For both DR & PS)
The result,
Front:1inch lowered
Rear:1.5inch lowered
Will raise the rear of 0.5inch more to make it even on fornt to rear when we install TEAS. Dont want to lower the car too, much.
Installation performed by SPEED CONCEPT (503)356-2222 PST.
Old 07-29-07 | 11:59 PM
isam250's Avatar
isam250
niceee, thats crazzyyy
Old 07-30-07 | 12:10 AM
r100s's Avatar
r100s
Bonus:
Got the Tanabe Front under chasis brace installed also.
Old 07-30-07 | 06:40 AM
Gernby's Avatar
Gernby
That's disappointing that Tanabe didn't give proper height adjustment with those. Using the spring perches to adjust ride height is half-assed since it doesn't allow to adjust damper travel separately from ride height.
Old 07-30-07 | 10:00 AM
r100s's Avatar
r100s
Well, this Tanabe Five for ISX50 has HELPER SPRINGS(also called tendam springs) which preloade the main springs so that ride height can be adjusted without changing too much of spring compression. (please search and learn more details about what helper springs do then you will understand what I am trying to info here.) Tanabe puts those helper springs for reasons...
Tanabe also has their line called "SEVEN" which has separate height adjustment but not available for ISX50s and those separate ride hight adjustment is for those who need extreme hight adjust ability. For most of ISX50 owners wont need that much of ride height adjustment.
