coilovers
no welding at all, just take out your suspension take the oem springs off, slid the coilover sleeves on then slide your oem bump stopper on, then your coilover springs, and then put your upper mounts on and install them back to your ride and that it no welding or hard work
You pull the strut/spring assembly out. Use a spring compressor, and compress the spring. (You can rent one from Autozone.) Take the spring out, and replace it with the sleeve/spring combo. Re-assemble.
You may want to cut down some of the bumpstop, to allow a little more suspension travel. Especially if you have them cranked down.
yea thanx na4now. but yea its just the sleeve and spring and the skunk2 , i waiting for the tien uppmount but the oem upper mount works fine if your not lookin for camber, the coilovers only cost me 110, but i did this for people that are on a budget and cant afford them tien rite away, and there lookin for the ride hieght
$110? all the sites i checked are around the $250 range... let us know where you got them from for so cheap =) if they are riding better than those 800dollar teins ill rather same the money and get this.
s'ok boost, i'd say 90% of the SC forums go the cheap way.
also for those looking into these, consider changing out the oem shocks as i have a feeling they won't last long with these spring/perch combos.
another thing is, what keeps the spring/perch attached to the shock? as far as i can tell, they just slip over the shock and rely on the weight of the car/friction to keep them in place.
