Disc Brake Hardware - please help
I have a GS400 and I was doing a suspension/rotor/brake upgrade and somehow I lost the little tension wire on the top of the pads that pulls them apart, none of the auto parts stores has them and unfortunately the closest Lexus dealership is about 3 hours away. I have a Toyota dealership down the street anyone know if a toyota vehicle uses the same brakes or utilizes the same hardware. Any input would be appreciated. Thanks
Thanks for the reply rominl, I don't post too much here just because usually I can search everything I need to know. Your name pops up a lot, so thanks for making this site the great resource that it is.
exclusive matchup
i don't recall there being any v shape wire spring in the rear. the rear is 2 pot one on each side.
chuck, i believe he's talking about the wire v-shape springs on the front calipers. i believe there are 2 per side. it's there to pull in the outer pads when the inner pad is pressed in
no probem jesod, always try to help
You will have to buy the hardware kit, im not sure if toyota uses them. Im sure they can cross reference it with lexus part numbers.
chenxingha
RX - 1st Gen (1999-2003)
08-16-08 11:08 PM
jucee187
Suspension and Brakes
08-12-04 10:08 PM
