Dropping and Camber/Toe
When dropping the IS, is negative camber a big concern? Are camber kits required? On my old car(G35 coupe), camber was a huge problem and ruined the inside of the tires. Is it the same case with the IS350?
Thanks in advance
Thanks in advance
Tech Info Resource
Search must be broken again.
There are NO CAMBER KITS for the ISx50. Figure out a toe that works with your alignment guy, or suffer the same fate you suffered with your Infiniti. Fashion has a cost.
You shouldnt have anything to worry if your drop is anything up to 2 inches, maybe 2.5. At that level camber can be from -1.5 to -2 on all fours. I dont think this is bad. Around -4 is when I would expect to see some inside wear, though Im sure some suspension experts can correct me.
i just had mines dropped with teins 1.6 F / 1.2 R and had the car aligned and they told me that the camber cannot be fixed. although my toe was fixed within specs and improved my camber by like 1 degree or so
Just had mine done yesterday. I'm dropped about 2 inch with Tein CS coilovers.
Front when I came in...................Rear when I came in....
Left................................................Left
Camber 1.5-....................................Camber 1.75-
Caster 7.5+.....................................Caster N/A
Toe 1/32 out...................................Toe 1/8 in
Right..............................................Right
Camber 1.5-....................................Camber 2.25-
Toe 1/32 out.....................................Toe 1/8 in
When I left...
FRONT..................................................REAR
Left..................................................Left
Toe 1/16 in......................................Toe 3/16 in
Right................................................Right
When I left...
Tech Info Resource
When I left...
When I left...
