are ls400 calipers worth $40 dollars for a front set or is that bad. i couldnt find any priceing on the search, what are the plusses of having them vs stock sc300 ones?
$40 for 2 ls400 4-piston calipers is a steal. Are you sure he's not talking about pads?? They will provide better braking power in the front, but you can't fit them under stock wheels.
High disk meaning the front wheels face should have a high disk to allow more clearance behind the wheel for the caliper to fit. It really depends on the wheel manufacturer.
i read in another thread that i cant use sc rotor is that true and if so what size do i need that will bolt onto the sc. also what all would i need to do the swap??? the cals would come off of ls400 so i would think it would have all the nuts and bolts.
In addition to the 95-00 ls400 calipers, you need the 95-00 rotors and pads. You also need the shorter ls400 caliper bolts or shorten your current sc bolts.
