Installing Supra TT brakes, questions...
high disc i think is what they are called.
if your rims are not going to clear BBK you can always stick spacers, push them out, create more room. However, since you already have a lower offset wheel over stock, depending how much clearence you need to clear the BBK, adding spacers might give you too much lower offset. if that happends, then your wheel will be past the fender.
i think it's worth a shoot though.
0494514110, 0494714010, 98, brakes, calipers, ebay, forum, good, gs, installing, lexus, remanufactured, shim, supra, tt
