TRD big brake kit?
That is the 94- LS caliper. I believe the caliper in reference was the 95-00 LS caliper, which is indeed four piston like this TRD kit.
These are the LS calipers of mention:
![](https://i61.photobucket.com/albums/h46/blizzy019/CIMG2128.jpg)
However, the TRD kit looks identical to the Supra calipers in terms of form. Perhaps the TRD kit utilizes aluminum rather than iron, but it appears that the identical mold is used for the TRD kit that was used for the Supra calipers.
If you want to achieve this look from the Supra calipers, begin by painting a base coat of 1200*F white engine paint. Then, go to the internet and print out a TRD logo, making it the appropriate size in a photo editing program. Cut out the letters, and -using rubber cement or a glue stick- afix them appropriately to the caliper. Cover with 500*F red gloss engine paint. Once cured, remove the letter cut outs and the adhesive residue. Finish with 500*F clear coat for protection.
check out stoptech.com i just got their 13.2" big brake kit its awsome
. only thing is it will not come with anything for the rear it is and complete front kit only. the weight savings is the best part
