Small problems after lowering
I got it lowered with espelir springs and l-tuned shocks. After about a week of driving the rear is sitting slightly lower than the front. Not much, it's a 2 finger gap all around but in the rear my fingers are tilted to fit unlike the front where my fingers are level.
Also the car feels bouncy now over bumps as if the shocks arent damping. It feels like the car is rocking front to back from the bounciness.
Are the shocks blown? When I push down on the rear it starts bouncing way too easily. I would think they're be more resistance and stiffness since the springs and shocks are stiffer than stock? I was told the set had about 7k miles on them.
fronts are typically a bit higher than rears, my friend has espelirs too. he's about 1.5 finger all around on 18's on kyb's. dont forget, espelirs spring rate is near oem, so there's relative closeness to ride, and l-tuned shocks arent too tight as well. suggest u check the shocks.
