Making the Tein CS's lower
Old 08-24-07, 05:58 AM
Rock-a-Lex
Rock-a-Lex's Avatar
I never heard of Tein CS's "tucking" on a 2GS...
Old 08-24-07, 10:08 AM
LALEX1
LALEX1's Avatar
Default >>>>>
Do we have the same definition of tucking?
Both my front and rear tires were tucked in the fender, I would say about .5-.75 of an inch and my cs were not all the way down. I have 20's on 245/35 in front and 255/35 in back. I will look for pics when I get home.
Old 08-24-07, 10:22 AM
chrispy
chrispy's Avatar
Tein CS will tuck tires if you have 20's all the way down. 19's or smaller you'll still have a small gap.
taeng
taeng's Avatar
lalex1 - It depends on how you want your stance. Someone people like it lower then others. It's really all a matter of opinion. A lot of people here agree that the CS's don't lower the car and tucks all wheels. If you are rubbing all over you might have the wrong combo offset/tire size. Post a picture so we can all see how your set up looks.
Old 08-24-07, 01:14 PM
Benjamin T
Benjamin T's Avatar
i don't see how people can run that low on the CS.
i have the v1.0's and the perches are at the lowest setting. with the damping even at it's stiffest setting, the front struts bottom outo n their stops because they don't have enough stroke to make up for the loss in height, so there is a lot of bashing and crashing to be experienced.
i also question the safety of taking off one of the two spring perches!!! is that even safe? i'm not saying that tein's stuff is bad, but i've seen the perch break into 2 pieces on a cheap set of sleeves on a honda... i don't have to tell you what the end result was
Old 08-24-07, 01:36 PM
bighitbike
bighitbike's Avatar
Definitely true. You shouldn't be rubbing with 20's even with them all the way down. You must have to big of tires or the wrong offset. And as for as i've seen, the CS' wont slam me the way I want them too.
Can we get some pics of your car all the way down?
Old 08-24-07, 01:49 PM
Benjamin T
Benjamin T's Avatar
Old 08-24-07, 05:09 PM
bighitbike
bighitbike's Avatar
Damn, I need lowerrrrrrrrrrr. I want those wheels though
Old 08-25-07, 06:55 AM
taeng
taeng's Avatar
Is all that bashing and crashing to be experienced with the V2's all the way down? Mine should be arriving soon and I plan to put them on the lowest setting. However I wouldn't want to experience all that "bashing and crashing"
Old 08-25-07, 11:22 AM
L3XOTIC
L3XOTIC's Avatar
EXACT MOTORSPORTS in MILPITAS CA has a part they install that drops your front end another inch. They are a supporting vendor on here. PM them, i believe they are username "Exact" or post this in the Cali regional section. Cali people mostly have these install and the front end tucks in.
Old 08-25-07, 07:21 PM
Benjamin T
Benjamin T's Avatar
those are 19's in the pic btw. but when i was on 20's i couldn't make those tuck either (as in no gap or even less) :huh:
california roads must be billard table smooth and paved with gold...
Old 08-25-07, 07:25 PM
Benjamin T
Benjamin T's Avatar
i created another thread asking about that, but no one has replied.
i bought a set of used v2.0's from another listmember here, but it's going to take awhile to get to me and have them installed. i still have my v1.0's here and i'm going to put them side by side and see what physical difference there are (ie. is the strut shorter).
i'm currently on STANCE GR+'s, which have a threaded body for independent height adjustment like the tein SS, but it has none of the noise the SS has... but everyone who rides with me are complaining it's too stiff, so i have to look at my options again
i wish HKS would hurry up and bring the hipermax 3 here already
Old 08-25-07, 09:13 PM
taeng
taeng's Avatar
time to find exact and see what the deal is...
Old 08-26-07, 06:25 AM
johnee78
johnee78's Avatar
Wink
If anyone wants information about how to make the front lower safely just send me a PM..
Old 08-26-07, 11:50 AM
L3XOTIC
L3XOTIC's Avatar
once again
EXACT in milpitas california......... get in touch with john
PAVGR
Suspension and Brakes
10-22-10 12:59 PM
acefalcon2
39
05-10-09 07:59 AM
na4now
07-11-07 01:25 PM
t0e
29
07-08-07 02:47 AM
tmf2004
15
08-18-05 05:53 PM
Quick Reply: Making the Tein CS's lower
