What can you tell me about eibach springs
Hi there. I am planning on getting the Eibach Pro kit springs. Since I am in Iceland can someone how much they cost in the US and how much the shipping would cost. Are they hard or comfy? I am a mega noob when it comes to stuff like suspension. Could you also attach some pics.
Check out www.tirerack.com for the prices. I'm not sure if they are willing to ship to you though.
I'm probably going to lower with eibachs myself soon so I cant answer your question.
Ride quality is not bad since the drop is conservative. But handling is much better, it is more responsive on tight turns. I have the Pro Kit and aftermarket wheels. The wheels are staggered size so I have 235/35/19 in front and 275/30/19 in the rear. With this setup, the od of the wheels are almost identical. However, there is a one finger fender gap in front and two in the back. When I had the stock 18s on, the drop was perfect all around because the rear wheels are .5 inch bigger compared to my aftermarket wheels. I think I will be getting 275/35/19s in the rear for my next set of tires to even out the fender gaps.
-TJ
Cycle Savant
Eibachs for the 350...
It cost me about $220 shipped in the U.S.
The ride is a little bit more firm, and is a lot more confident in turns and twisties.
I kept the same size wheels/tires, so the ride is still comfortable and quiet at a cruise.
I definately suggest them for something more sporty, but still forgiving.
Cycle Savant
I would have never changed the springs if the car got too bumpy. After trying it on other people's cars, I found the Eibachs perfect (for both aesthetics and handling).
However, I have kept the same size wheels and tires. If you have or get bigger wheels with smaller tires, ride quality will definately be compromised...
2IS OG
Javier
Bumpstop cut?
A lot of people who complain of a harsher ride are not only swapping springs, but reducing their tire's aspect ratio from 40 to 35 or 30 to accomodate larger wheels. Your ride quality has much more to do with the size tire you run than whether or not you're using Eibachs. I'm running Eibachs on my car, and I kept the stock-sized tires on my aftermarket wheels. My ride quality is practically identical in comfort to my stock suspension. Ask anyone who's ridden in my car (and there's lots on this board) and they'll tell you the same thing. So, to answer rfx45's question, they are still very comfortable.
Javier
Javier
