Wheel sensor rusting into the hub assembly
In the process of changing out the rear hub assy. I had to swap the wheel sensor from one hub to the new hub. I found that the sensor was pretty well stuck in the hub assy. due to rust. Is there anything I can coat the sensor with that would be safe and would prevent any rust from forming there? I broke the sensor in half trying to remove it.
biacs
07-06-15 06:19 AM
