Ikeya Formula w/pics
Old 09-13-07 | 12:03 PM
LexAnt's Avatar
LexAnt
Default Ikeya Formula w/pics
As promised, here is the update. Well I received the rears and finally got all 12 of the arms installed. Didn't take great pictures, all from my phone.
Front (getting a tie rod replaced)
Front Lower Driver
Here you can see how they manage to maintain proper roll geometry by keeping the control arm parallel to the ground. When you lower a car, the arms tend to bowleg; these control arms fix that.
Rear Passenger
You can pick these up via Carson if you wish.
Overall, the car rides GREAT! If you have the Daizen control arm bushings and/or camber kit, the ride will not change much if at all. The car has better turn in and the steering response is quicker. As the car sits right now, it handles like a go-kart in the turns. In the future, the CS's are getting tossed in favor of some TS coilovers.
*edit- also not shown are the upper control arms. These have a large amount of adjustability. Right now as is, the control arms are set right in the middle as you can see from the front picture. These can push the tires out more by about 1/2inch in the front and 3/4inch in the rear.
*posted here in the open forum to let people see them before it gets moved to the suspension section.
Old 09-13-07 | 12:12 PM
chanh55's Avatar
chanh55
Wow.... nice.
Old 09-13-07 | 12:13 PM
ACleanSC4's Avatar
ACleanSC4
Damn you for giving me more things to buy...
Old 09-13-07 | 02:24 PM
Fireblaze's Avatar
Fireblaze
Nice! If I was planning to go all out suspension-wise with my car I would totally do that. Good job of doing things right, especially with something as important as your suspension.
How do the C-S's ride?
Old 09-13-07 | 02:29 PM
StiCk3's Avatar
StiCk3
damn, $4500 for all twelve???? I wish i got these instead of replacing the old ones with Supra OEM....those look great!
How much does one control arm weigh?
Old 09-13-07 | 03:39 PM
G Star's Avatar
G Star
atta boy!
Anthony you got some crazy stuff coming on. Can't wait to see you run those Endless racing brake kits.
Old 09-13-07 | 03:40 PM
LexAnt's Avatar
LexAnt
The CS's ride pretty smooth even with these arms. Though it isn't stiff enough for spirited driving without rubbing the front fender liners. I went lower than what I was previously set at.
The front lower control arms were about the same weight; they sure do got a lot of mass to them. The other arms were fairly light, probably on the same weight as stock if not slightly lighter.
Originally Posted by Xotic sC
atta boy!
heck yea!... soon enough soon enough
Old 09-13-07 | 04:56 PM
SickSC3's Avatar
SickSC3
damn that looks bad ***
just wondering how and the hell did you get your car on a lift with your kit?
Old 09-13-07 | 05:22 PM
howiedoit's Avatar
howiedoit
wow, nice! great...another thing to buy...
Old 09-13-07 | 05:51 PM
BLK13X's Avatar
BLK13X
Mortgage Slave
Very nice! All these temptations
Old 09-13-07 | 05:59 PM
IS_Sunny's Avatar
IS_Sunny
Really nice man. Way to go all out... gonna be sick
Old 09-13-07 | 08:59 PM
LexAnt's Avatar
LexAnt
well they had to triple ramp it up. the alignment racks already come with one that are permanently attached. Then they had another set of metal ones to use. On top of that, we had to use boards as well. So... yea
Old 09-13-07 | 09:17 PM
SickSC3's Avatar
SickSC3
Originally Posted by LexAnt
well they had to triple ramp it up. like the alignment racks already come with one that are permanently attached. Then they had another set of metal ones to use. On top of that, we had to use boards as well. So... yea
ic.. i guess thats what i need to do then to bad i cant take my side skirts off like i use to do when i brought it to a shop. you should try it, its alot easier for them to get on the lift.
Old 09-14-07 | 11:22 AM
solo's Avatar
solo
holy pure sex.
Old 09-14-07 | 03:14 PM
Seize's Avatar
Seize
Loves Snickerdoodles!
Ooohhh those are sweet
