Lowering Springs: Alignment Friendly
09-15-07, 11:00 AM
Hello,
I have finally decided to lower my 2003 Sport Design but I would like to maintain consistent tire wear.
So my question is, what have any of you experienced on the board that will give you the Max Lowering Height while maintaining minimal camber wear.
Max Drop while maintaining perfect camber.
Thank you!
09-15-07, 12:56 PM
wrong section....SEARCH IS YOUR FRIEND. Topic has been cover too many times
09-15-07, 02:53 PM
I have.. but the ones I have found does not discuss about alignment.
Pro-kit?
09-15-07, 02:57 PM
I think 1.25" is about the max you should drop if you want to be able to retain OEM camber spec. I have L-tuned springs that lowers ~1" all around and the alignment shop was able to put the camber to OEM spec.
09-15-07, 05:52 PM
Quote:
Originally Posted by
4GRFSE-GFM
Thank you!
huh?
10 characters
(did i interpret that wrong?).......................max drop/slammed but maintain perfect camber?
09-15-07, 06:10 PM
He means like how far can you go before you start having nonOEM camber
09-15-07, 09:03 PM
I'm drop'd 2" and my camber is at -.25
09-16-07, 12:06 AM
bighitbike
Thank you! I knew there would have been confusion. I just couldnt have thought of the correct wording.
So L-Tuned? How about Pro-Kit?
Anything else?
09-16-07, 10:21 AM
my friend is on eibach and gab shocks. about 2 finger all around. minimal camber/tire wear issues. but then again, he barely drives the car.
09-16-07, 07:18 PM
I see. How are the eibach prokit on the alignment machine? Dead center?
The 4 finger OEM gap is unbearable!
09-16-07, 07:28 PM
i think so long as your tech can get your alignment back into oem spec, it should be ok.
others, please chime in on this.
09-16-07, 07:30 PM
Yeah that is the main concern. I want the lowest possible springs where when on the machine, i can get the alignment back to zero degrees.
09-16-07, 09:14 PM
i have the eibach pro kit and my alignment is perfect.
09-16-07, 09:22 PM
GSquicksilver, I have the same wheels as you. GS430 18". Do you have pictures of your car with the springs installed?
09-18-07, 11:31 AM
I also have eibach prokit and no camber issue.
