Anyone completely replaced their suspension?
Everytime I ride in a newer car and then ride in mine I can totally feel the difference. My front end rattles, I need a upper control arm for the right rear wheel. Question is how can I get the car back to riding like its new? Change shocks, ball joints, and all upper and lower control arms? Or just the bushings.... If anyone has done this about how much did it cost? Where did you get the parts? (daizen?)
Brian, sounds like you'll need a whole new suspension overhaul...Ride quality suffers mainly because the bushings go bad if you have more than 120K....
Change the following items:
1) Bushings LCA, UCA, Fr & Rr
2) Shocks, springs
3) Steering rack bushing
4) Sway bar bushing
5) Get an alignment
6) Check your tire pressure
It's not going to be cheap, your looking at least 1.5k or more with labor...
I have Tein CS with all Daizen bushings...This combo will cost probably 2 times the cost than what I suggested above..But in the end, it rides and drives like a Lexus should..
2) Shocks, springs
4) Sway bar bushing
5) Get an alignment
2) Shocks, springs
4) Sway bar bushing
5) Get an alignment
2) Shocks, springs
4) Sway bar bushing
5) Get an alignment
I dont know it kind of feels like the ball joint.... ive had that feeling before in another car and they changed the ball joint and the car rode fine afterward. Im in nyc=pot hole city so its possible the ball is shot. Ima take it to have it looked at to get a final say
Im gonna take it to the mechanic probally weds morning and have them put it on the lift and go from there. I neva felt how a lexus sc is supposed to ride. I cant bear to stand it anymore.... btw I have tt eibachs and tt shocks all around. 19x8.5 19x9x5
Say the springs are sagging, but are 13 years old. Do springs really wear. Does the spring rate change over time from wear even a slight change?
I have replaced the entire front suspension except for the springs and the upper control arms. Everything else is new. I am now working on the rear suspension and have changed the upper mounts, shocks, sway bar bushings, spring bumpers and spring insulators. It was worth the money in my opinion. I bought all the rear control arms with only 30,000 miles for $100 and I plan to change all those out when I install new wheel bearings. Then I plan to get new front upper control arms and then possibly change all the springs out as well. I think they're only like $60 each so its not that bad. At this time I want to keep it stock. The rear suspension feels great. There's still something in the front that is kinda rough when hitting a bump so I plan to change out the front wheel bearings and upper control arms. Its not cheap to do but well worth it.
Ok... i just took the car to a random mechanic to have them put it on a lift to see what they say.
Verdict:
BAD: Passenger ball joint
BAD: Pass&Driver inner and outer tie rods
BAD: Sway bar links
BAD: Pass&Driver LCA bushing
OK: Driver ball joint (but he said to change it, its gonna go soon)
Where and what parts should i get? Im kinda leaning toward supra mkiv because of better make and its cheaper than lexus parts.
question: 1. should i upgrade the sway bar? 2. Change the front shocks? I bought them used with my tt eibach springs
Verdict:
BAD: Sway bar links
i've had the same issue in all 3 of my sc300 ranging from 92 to 97. i've had every single suspension peice redone. i can tell you right not its most probably upper balljoints because thats what happened to all of my sc's or a bent wheel. i would suggest replacing the control arms.
KickItOut
Suspension and Brakes
01-22-14 07:32 AM
ceelo
07-07-11 04:26 PM
