Changed my Rack Bushings .. Crazy Pictures
#31
A lot of the bad bushings I have seen look really oil soaked, possibly by power steering leakage. Could be because of soaking with penetrant during removal. My real point was that my bushings were tight and I still had uneven pavement pull, and I think its because of directional a/s tires.
#35
generaly you dont change power steering rack boots, if there torn you will usualy need to change the rack. If you want to check and see if the to see if ur internal power steering gaskets are leaking, all u need to do is put a pin hole in the boot and if it leaks then thats the problem.
BayAreaLex
11-05-12 03:59 PM
